39 M Decal placement
usnfarmall
06-21-2005 18:10:51
I was wondering where the decals are placed close to original. I have Hugh"s book but dosent help much. Is there any place else to look? I have seen many pictures but the decals seem to be different along with the placement, the newer the M got. Thanks for all the help.
jakee
06-22-2005 18:29:41
 Re: 39 M Decal placement in reply to usnfarmall, 06-21-2005 18:10:51
okay try this at border book stores--- ICONOGRAFIX PHOTO ARCIVE by P.A.LETOURNEAU --- FARMALL-- M-- SERIES,about 30.00, pictures takenout of the harvester arcives.remember 1939 and part of 1940 is diffrent from the other year M,s. 1947 and back is diffrent also like decal,s used. i have had 3 diff- 1939 M,s.
CNKS
06-22-2005 11:20:01
Never heard of the book you are referring to. Guy Fay's Farmall Letter Series book is the place to look. Some models are missing, but you can look at other models and get a placement no one will argue with you about (they don't know either). The decal placement at the factory differed from tractor to tractor also, as Charles noted.
Charles Park
06-22-2005 06:12:00
I had the same problem. Posted this question after buying the book. Best I can determine is that the factory did not follow a strict policy on the placement of decals.
So what I think you need to do is find a picture or go to a show and find one that you like and then copy the placement on that one. Hope this helps a little.
