Fuel line screen help
brainerd dave
06-22-2005 05:22:42
I put on a rebuilt carb that I picked up on EBay and it's leaking like crazy at the friction ball just in front of the starting shutter shaft where you connect the choke rod. There is no brass screen on the end of the fuel line connecting to the carb. Is this part of the problem? I'm not clear on the purpose of the screen.
CNKS
06-22-2005 11:14:56
 Re: Fuel line screen help in reply to brainerd dave, 06-22-2005 05:22:42
Andy is correct, but the screen/filter is not the cause of the leak. Sounds like a lousy rebuilt job, I've never seen a rebuilt one leak there -- in fact I don't think I have ever seen a leak at that location.
Andy Martin
06-22-2005 05:41:05
The inlet screen is to keep small debris from holding the needle valve open, which is what your problem sounds like. You can put an inline filter just in front of the carburetor to replace it. Clean everything up real good.
