350 conversion - Opinions ??
Illinois Boy
07-08-2005 08:10:18
I was thinking of converting my old 350 from gas to diesel for various reasons.
Do you think it would be worth the trouble and expense - or should I just buy another tractor.
RN
07-08-2005 17:44:38
 Re: 350 conversion - Opinions ?? in reply to Illinois Boy, 07-08-2005 08:10:18
350D engine- I have a 350D, fairly good engine for its time- now about 40+ years old, parts are $$ and a little slow to find when fixing. Not recomended as a conversion project. Other engine to switch into would be the 460 IHC engine- check archives for posting about install, 460 engine bolt pattern mounted to 300/350 transmission bell housing, frame rails from 460 installed, other front end parts from 460 also used. I remember this thread as a 460 with transmission casting broken for some reason and a 350 gas availble with bad engine, swap resulted in a usable tractor made from 2 non-usable donors.
Hugh MacKay
07-08-2005 16:41:39
Dave is right, you could probably buy yourself a couple of 560 or 656 diesels for less money than your current proposal.
Red Dave
07-08-2005 09:01:32
It probably would cost more and be more trouble than it would be worth.
It would (in my opinion) ruin the collector value of the tractor to have some off-brand diesel engine in it.
If it was me, I'd rather sell the 350 and put the money toward the tractor you really want.
Turk
07-08-2005 08:19:05
Unless you happen to have a 350d that is completly shot but has a good engine, just go buy one.
Illinois Boy
07-08-2005 09:05:27
 Re: 350 conversion - Opinions ?? in reply to Turk, 07-08-2005 08:19:05
Thanks Guys...
I really don't want to sell her... I kinda thought I'd get the answers you gave.
If I did convert - it would have to be a diesel from a 350 - but then again, I'd be messing with a perfectly good tractor!!
Just a thought - THANKS!
Steve from MO - dangit!
07-08-2005 09:24:24
 Bad idea. in reply to Illinois Boy, 07-08-2005 09:05:27
The original diesel engine for that one was Continental, not IH. I don't know about its durability but parts are hard to find and very pricey. You could buy a whole heck of a lot of gas for the price difference.
KAK
07-08-2005 16:46:26
 Re: Bad idea. in reply to Steve from MO - dangit!, 07-08-2005 09:24:24
The Continental engine used in the 350 were not very durable. They also had problems keeping the injection pump in time. Not a good idea.
