300 Utility Won't Run
300 Utility
07-08-2005 23:11:31
My dad and I have been trying for the last few years to get an IH 300 Utility to run. Finally got her going last night, and it runs beautifully for about 2 or 3 minutes then it will lud down and die as if it is being overpowered by something. Do you have any thoughts on this? We are planning to do a complete rebuild on it this winter since it sat idle for about 30 years so that may be our best answer. Any help you can provide is greatly appreciated.
Bob
07-08-2005 23:40:33
 Re: 300 Utility Won't Run in reply to 300 Utility, 07-08-2005 23:11:31
It's either running out of gas, due to a restriction in the fuel system. or the spark is failing, due to a coil that fails when it warms up, a bad condensor, or possibly a bad ignition switch.
What you need to do, is, when it stops, hook a test spark plug into one of the leads, and see if spark has been lost.
If you have spark, you need to find why it's short of fuel. If no spark, figure out why spark is being lost.
