Does this 300 utility have a TA
JamesR
07-17-2005 18:12:56
Yesterday I looked at a International 300 Utility. No mention was made of TA, but I noted a horizonal lever, with a release, located on the right side of the operators seat. What is this lever for? Any help will be appreciated.
gene b
07-18-2005 03:48:19
 Re: Does this 300 utility have a TA in reply to JamesR, 07-17-2005 18:12:56
So what happens when you pull the lever. PTO and TA and other stuff was an option when the tractor was built. You never know what someone has changed since new.
CNKS
07-17-2005 19:53:26
The lever would be on the left. If it is missing look for an R or S code following the chassis serial number. Otherwise it doesn't have one.
Thack
07-17-2005 19:51:01
I think all the 300U's had a TA...Guys?
JakeF
07-18-2005 00:32:57
 Re: Does this 300 utility have a TA in reply to Thack, 07-17-2005 19:51:01
It was an option. We have a 300 U that has a rear mount forklift and no PTO or TA. It was ordered new that way to be turned into a forklift.
CNKS
07-17-2005 19:54:27
Most, it was not "standard"
harnessbc
07-17-2005 18:17:06
..... .james, hi..... .i believe that lever would be to activate the pto..... ..
