Front Emblem
Charles Park
07-27-2005 06:16:18
Bought an aftermarket Farmall emplem for the radiator hood. The hood has two holes almost in the center for what I assume is the mounting bolts. The aftermarket emblem has the holes on the very ends.
How was the original mounted to the hood? Bolts in the middle or the end? I had rather not drill holes in the hood becuase I want it to be like the original.
iester
07-27-2005 22:02:12
 Re: Front Emblem in reply to Charles Park, 07-27-2005 06:16:18
Remind's me.. I bought farmall 350/350 utility side emblems from a vendor.Vendor said would fit either.. Not true ..Won't fit utility to big and pins dont't line up.
scruffyia
07-27-2005 08:09:37
I agree with Don. If your nose has two emblem screw holes close together the nose came off a Super M, it's not the original M nose.
I'd drill the new holes in the super M nose on your farmall M tractor and put on the emblem and call it good.
If you want it to be original you'd need to get a farmall M nose to replace you farmall super M nose.
And where did you get the emblem??? I need one also!
later,
scruffy
Charles Park
07-27-2005 12:26:42
 Re: Front Emblem in reply to scruffyia, 07-27-2005 08:09:37
Thanks for your reply. O.E.M. has these. 800-283-2122.
Don L C
07-27-2005 07:30:49
Charles---Your hood is for a SUPER M...the new emblem you bought is for a standard M .....don
Charles Park
07-27-2005 12:29:02
 Re: Front Emblem in reply to Don L C, 07-27-2005 07:30:49
Thanks. This was the hood that has been on the tractor since my childhood. Guess it will stay but do not know how it ended up on an M. I will retrofit the emblem to fit.
CNKS
07-27-2005 17:32:00
 Re: Front Emblem in reply to Charles Park, 07-27-2005 12:29:02
Are you SURE it is an M? Look at the serial number tag. Serial prefix for an M is FBK, for a Super M, SM. If it is a Super M, C-264 will be cast into the right side of the block, M engines will have no notation, except for the prefix FBKM STAMPED on the pad on the block under the number one spark plug. I just think it is strange that it has a SM grille, if you are familiar with the tractor.
scotty
07-27-2005 06:26:41
Charles, It depends on which tractor you have. Example, my 42 Farmall A has the wide chrome emblem, my 49 Super A has the small square IH emblem mounted in the center. Which tractor, and maybe someone else can help you out!
scotty
Charles Park
07-27-2005 06:40:28
 Re: Front Emblem in reply to scotty, 07-27-2005 06:26:41
Sorry, this a Farmall M. Would guess the emblem to be about 8-10" in length.
I just want this thing to be correct in any way I can control. Wish I could find an old emblem and clean it up. Thanks for your help.
RustyFarmall
07-27-2005 06:23:47
It sounds like the grille you have is from a super, which used a small IH emblem. The grilles do interchange, just fill the holes you don't need and drill new holes where you do need them.
KRUSS
07-27-2005 07:34:07
 Re: Front Emblem in reply to RustyFarmall, 07-27-2005 06:23:47
Just a tip here. Put locktite on the screws or bolts you fasten the emblem on with. They sure do go missing a lot of times.
kfox
07-27-2005 11:54:06
 Re: Front Emblem in reply to KRUSS, 07-27-2005 07:34:07
How were the origional emblems finished? I have a 41 H with what appears to be the origional emblem on the grill. It's in good condition except for at least two coats of red paint. It's a sharper stamping and the letters are better than the aftermarket one I bought to replace it with. Its made out of tin instead of aluminum like the aftermarket emblems. I would like to see an origional in good condition to find out how they were finished. (Polished, or painted ? )
ken
