Well, Rats!
Allan in NE
07-28-2005 05:48:49
Shucks,
Went to strap these bad boys on my 686 'cause the local Co-Op is coming in the morning with a Big-A to sling phosphate.
Tractor's prior owner had run the silly thing with the wheels dished in. So, this means I gotta swap all the lugs around to the other direction. Darned tires are loaded too.
Worked until dark last night and got one wheel moved in on the rim. Forgot what a job that was; not to mention the rust and frozen lug bolts.
Geeze! :>(
Allan
third party image
brian 1
07-28-2005 08:04:31
 Re: Well, Rats! in reply to Allan in NE, 07-28-2005 05:48:49
If you were in Missouri you could try them on the other side instead of turning them around. ;-)
Allan in NE
07-28-2005 08:11:19
 Re: Well, Rats! in reply to brian 1, 07-28-2005 08:04:31
Brian,
Don't think that didn't cross my mind for a few seconds there when I realized what was going on. :>)
The old brain was trying to rationalize the backward tread along with the added benefit of less work. :>)
Oh well, we do what we have to do.
Allan
Illinois Boy
07-28-2005 07:11:57
Allan,
You can always put those bad boys on your Chevy pick-up. Might take a little Nrbraska Engineering, but I have faith in ya'!
RustyFarmall
07-28-2005 06:28:12
That would be a job allright, but I think you still got off pretty lucky. I had to do the same wheel reversing thing on one of my Hs, took me about a week to get some of those bolts out of the cast center.
Allan Clapp
07-28-2005 06:31:25
 Re: Well, Rats! in reply to RustyFarmall, 07-28-2005 06:28:12
Mornin' Rusty,
I'm so accustomed to them being loose from being changed every so often.
Boy! When they stay in the same position for years on end, they really have a tendency to freeze up, don't they? Groan! :>(
Aw well, nice to be out in the sunshine and air again tho.
Allan
RustyFarmall
07-28-2005 06:46:42
 Re: Well, Rats! in reply to Allan Clapp, 07-28-2005 06:31:25
Yep, my tractor was 60 years old at the time, I'm pretty certain that part of the tractor was all original, just like it came from the factory. I tried cleaning those bolts up so I could reuse them, but by the time I got the rust knocked off, some of those bolts were only about 1/2 the diameter they should have been. Kinda scary to see that after I had been using the tractor.
Illinois Boy
07-28-2005 07:30:05
 Re: Well, Rats! in reply to RustyFarmall, 07-28-2005 06:46:42
third party image
Probably won't fit on my RED 350 - will they fit this one?!?! : )
Ouch - hey, quite that - that hurts!!
scotty
07-28-2005 09:19:59
 Re: Well, Rats! in reply to Illinois Boy, 07-28-2005 07:30:05
What the heck is that thing!!!
scotty
Illinois Boy
07-28-2005 09:34:02
 Re: Well, Rats! in reply to scotty, 07-28-2005 09:19:59
It belongs to my neighbor that I help do hay with.
Pitiful - ain't it!?!? He thinks it's the berries 'cause it's new with AC and heat.
I call it the "sissy tractor"...
brainerd dave
07-28-2005 12:48:46
 Re: Well, Rats! in reply to Illinois Boy, 07-28-2005 09:34:02
Heat and AC? I believe I could get sissyfied if nobody was lookin.
scotty
07-28-2005 09:40:34
Nah, just kidding you. I made the mistake of posting a picture of my Massey diesel on here once and did I catch heck for that! Ill take that 350D you got though!
scotty
Illinois Boy
07-28-2005 11:23:32
 Re: Well, Rats! in reply to scotty, 07-28-2005 09:40:34
Not a problem scotty,
That thing IS a "sissy" tractor!!! I tease him all the time about it he's got two of 'em - in his defense he's also got two 1086's and lets me borrow one when I need it.
My 350 is not a "D" - just a gas burner...
Glad it's not as hard as parts are to fine for the D...
RustyFarmall
07-28-2005 08:00:08
Looks you need to bring that one inside where it's warm, it's starting to turn blue from the cold.
