Extended Axels ?????
JC in ky
07-30-2005 16:37:19
I have just aquired a 1206. I was looking over the tractor and noticed it has somthing like axel extentions added to the rear axel. I have never seen any thing like this before. I wondered why the tractor was so wide. lol. I was just curious to see what you guys kno about them. They look factory but might be a dealar option. Im not sure. The seral # of the tractor is 13934 if that helps. Well Hope I haven't bored youall to death with this. Thanks for any info fellas. JC in Ky
FARMALL FRED
07-31-2005 13:17:10
 Re: Extended Axels ????? in reply to JC in ky, 07-30-2005 16:37:19
Itīs an option from factory for wide tread.
Just a extra hub housing bolted on the carrier.
RN
07-30-2005 17:14:29
Axle Extension? As large tube on wheel to bolt a dual tire setup onto? Tube/sleeve on axle with axle stub added instead? IHC had about 100 inch track axle option for some models- noted for cotton field use. RN
JC in ky
07-30-2005 17:56:52
 Re: Extended Axels ????? in reply to RN, 07-30-2005 17:14:29
Wel1 Its bolted onto the axel before the wheel hub about a foot extention on each side. I kinda figured thats what they were for but I really wasn't sure. Thanx JC
