6 or12 votls
Hoover
08-07-2005 04:20:37
HI! I have a 1954 super MTA I have working for a year now I'm just about done with it so it. The batter is under the seat.
Denny
make pancakes maybe
08-07-2005 14:02:34
 Re: 6 or12 votls in reply to Hoover, 08-07-2005 04:20:37
With the 'batter' under the seat you might want to make pancakes!
Dave in CT
08-07-2005 11:17:38
My 2 cents would be, if you go with the 12V conversion, do the three-wire setup. It's not that much more work, since you are redoing things anyway. Your charging at low RPMs will kick in faster.
Hayfarmer
08-07-2005 11:01:27
The SMTA was originally 6 volt. It may be 6 or 12volt depending upon what has been done to it. If you go with the 12 volt you will need a 12 volt charging system, an alternator is easiest, and a resister ahead of the 6 volt coil or 12 volt coil with resister. If you need wiring for that check in archives for an excellent diagram by Bob M. I would reccommend the 12 volt but the purists will argue. Anyway you just gotta know what it was set up for before you got it.
Gary Sparks
08-07-2005 08:53:54
How do I wire a 12 volt alternater& battery on a Farmall H with Mag?
nc140man
08-07-2005 07:43:49
If it"s wired for 6 volt wouldn"t you need 6 volt back in it if you don"t want to burn out 6 volt components? 8 or 12 volt batteries wouldn"t charge properly on a 6 volt system. I have a 6 volt system on my "61 140 and it works perfect! With lights and starting also! Why mess with something if it works fine? Scott
Nebraska Cowman
08-07-2005 04:23:56
You do what you want but I'd put a 12 volt battery in it.
Harley
08-07-2005 10:52:12
 Re: 6 or12 votls in reply to Nebraska Cowman, 08-07-2005 04:23:56
Me too Howard. That"s like running a tube type tire on a semi in this day and age of tubeless. They made 12 volt so it would have more power. I have both my 6-volt M"s changed over to 12-volt one wire alternaters and it is the cat"s meow. Harley
Randy (Ont)
08-07-2005 07:29:47
I just got an A running for a friend. The six volt battery (new) didn't seem to have the guppies to spin the engine at a sufficient speed, so on the recommendation of a coworker, I installed an 8 volt battery of same physical dimentions. Works like a charm. Apparently old car buffs like the 8 volt battery as well.
Red Dave
08-07-2005 09:49:27
 Re: 6 or12 votls in reply to Randy (Ont), 08-07-2005 07:29:47
If a 6 volt battery doesn"t have enough "guppies" to spin an A, the problem isn"t with the battery.
Randy (Ontario)
08-08-2005 17:19:30
 Re: 6 or12 votls in reply to Red Dave, 08-07-2005 09:49:27
The starter checks out and engine spins by crank well. But thanks for the helpful info. I'll be sure to pass it on to the others that recommended the 8 volt to me.
