Farmall H Radiator
AH64D
09-19-2005 12:50:54
I am restoring a 1947 H and am concerned the non-pressurizing radiator I installed, pre 1943 radiator, will start boiling fluid overboard when I get it up to temperature. The original radiator had a pressure cap with the overflow at the cap. This replacement radiator has a non-pressure cap with the overflow line below the filler neck. Is this going to be an issue? I thinking the $90 bucks I spent on this radiator is not the great deal I thought it was. What do ya think?
Thanks,
Ron
The Red
09-19-2005 14:17:51
 Re: Farmall H Radiator in reply to AH64D, 09-19-2005 12:50:54
At most, the unpressurized will be 10 degrees warmer. Pressurized I believe is only at 8 psi.
Nebraska Cowman
09-19-2005 12:55:01
Naah, unless you realy work the devil out of it those old Farmalls never even get warm.
RustyFarmall
09-19-2005 18:12:34
 Re: Farmall H Radiator in reply to Nebraska Cowman, 09-19-2005 12:55:01
Cowman is correct, you don't need to worry about it.
AH64D
09-20-2005 06:38:40
 Re: Farmall H Radiator in reply to RustyFarmall, 09-19-2005 18:12:34
Thanks all, Good to know.
