axle housing gasket replacement question
Tom F
10-04-2005 13:31:02
can i replace the rear axle housing to transmission gasket by removing rear wheel assy., bearing retainer, unbolting the housing and slide it off the axle shaft on my '52 super m or is there more to it? I dont want to remove trans. top cover and bull gear retainer if I dont need to. are the seals and gaskets still available?
Larry in CO
10-04-2005 15:54:49
 Re: axle housing gasket replacement question in reply to Tom F, 10-04-2005 13:31:02
Tom,
I did this exact thing on my H a couple of years ago. I would expect the procedure is the same except the parts are a bit heavier. Click below to see the procedure I used. HTH Larry
