Fuel Tank
Pamike
10-09-2005 13:21:51
Any suggestions on repairing leak in gas tank? Its a hairline crack about an inch and a half long. Thanks
F-Dean
10-10-2005 04:38:12
 Re: Fuel Tank in reply to Pamike, 10-09-2005 13:21:51
Check with your local radiator shops to see if they will dip and seal it. This will seal your leak, cure/prevent any rust problems you may have and, as a side benefit, prepare the exterior for painting.
shoe
10-09-2005 20:04:39
Had the same kind of problems with a tank a couple
of years ago, had a crackin a seam. I used a
product called PC7. It is a product some what like
JB weld only three times as good. It comes as a
two part compound but unlike JB weld, this is in
a paste form. Mix equal parts together and apply with putty knife or something simular. It sets up hardas a rock. Heat doesn't bother it, gasoline,
oil, or cold. It's a quick fix and it works. It can be bought at automotive parts stores or hard-
ware stores like ace. This stuff can be drilled
and tapped for threads even. And it doesn't crack
with age give it a try,it's a cheap fix. Just make sure the surface is clean when you apply it.
Good luck, let me know if you try it and it works
for ya.
K.B.-826
10-09-2005 18:35:53
Call around and see if any of your local radiator shops or welding shops will do it. Soldering is the best fix in my opinion, but it is a very dangerous job for anyone but an experienced professional.
NDS
10-09-2005 16:38:50
Permatex has an epoxy made for gas tank repairs. They claim it will repair cracks up to 4 inch and holes up to 3/8 inch permantly. I have never used it but it gets good reviews.
El Toro
10-09-2005 14:38:20
As Geoff said to clean it very well and use a large soldering iron. Use that soldering paste too. Don't smoke or have any flames nearby. The soldering iron will do a good job and is safe. Hal
230,H,M
10-09-2005 13:55:44
CAUTION ??? Soldering generates heat possible sparks. Doing this could cause an explosion.
Geoff NY
10-09-2005 13:26:15
clean the metal arond the crack well and solder
champspa
10-09-2005 14:42:15
 Re: Fuel Tank in reply to Geoff NY, 10-09-2005 13:26:15
don't sand or scrap on the tank! there is and epoxy that is used on them now
