Steering in the snow
PurdueAg
10-17-2005 17:57:15
How well do narrow front tractors (I have an H) steer in the snow? In sand, a sharp turned wheel just pushes straight forward. Do you have to brake the rear wheels separately to steer in the snow? I have never driven a tricycle tractor in the snow, but it would be helpful to know what to expect, as I am trying to rig up a snow plow.
Thanks,
Tony
riverbend
10-18-2005 14:14:40
 Re: Steering in the snow in reply to PurdueAg, 10-17-2005 17:57:15
Putting chains on the front will make it will steer better. If you push too big a pile of snow, the front end will still slide. Pick up the bucket a little and the extra weight will make it steer again.
Brent in IA
10-18-2005 04:30:39
Snow isn't the problem, it's the ICE that is tough to steer on. A tricycle/narrow front tractor will be much easier (and more fun in my opinion) to clear snow with (I have both narrow & wide so I can have an opinion) since they turn very tight.
gene bender
10-18-2005 01:30:11
We have used these for 50 pluss yrs now and they steer ok in snow it is all in the operator. H would be a great tractor for pushing snow with front blade.
Sloroll
10-17-2005 18:58:19
Narrow or wide front, think of your front wheels as skis. Be ready with your brakes.
Mike Van
10-17-2005 18:11:14
Tony, you will have to use the brakes to steer in snow.
PurdueAg
10-17-2005 19:14:08
 Re: Steering in the snow in reply to Mike Van , 10-17-2005 18:11:14
Thanks for the info, guys. I'll need a little practice with the braking (just not right away, hopefully (snow)! :)
Tony
