Fuel tank cleaning in NW MO
farmallmark
10-19-2005 14:02:34
We were going to take our fuel tank off of our combine to have cleaned. Is there anybody in Northwest Missouri around the St Joseph/ Maryville area that does this? Thanks for any information. Mark
farmallmark
10-20-2005 15:17:38
 Re: Fuel tank cleaning in NW MO in reply to farmallmark, 10-19-2005 14:02:34
We are trying to clean out grain dust build up on the inside. Will ask the radiator shop if they can do it. Thanks, Mark
Slowfolk
10-20-2005 06:07:50
What are you trying to clean from the tank? I also have a tractor gas tank needing cleaning as it had rust build up in the tank. I drained the tank and put small stones and water in the tank and shook it back and forth until I had most of the rust particles out of the tank. When running the engine I still gets small particles filtered in the gas bowel. Let me know if the radiator clean shop works for you.
Thanks
Slowfolk
504
10-19-2005 20:55:40
Mark, your local radator shop should be able to take care of it. kjm
