Order Farmall Cub Parts Online
Cub Oiling Problem
Tommy D6-8U
10-29-2005 09:29:20
Hi folks,
Just finished rebuilding a Cub engine and have been unable to get any oil to the oil filter. Checked pressure at the oil galley plug on the rear of the engine (left side) and measured 48 psi. I cannot figure out how the oil gets to the passage in the filter housing. Obviously it is plugged somewhere but can"t find where it is fed from. Any ideas or help would be greatly appreciated.
Tommy D6-8U
El Toro
10-29-2005 14:03:25
 Re: Cub Oiling Problem in reply to Tommy D6-8U, 10-29-2005 09:29:20
There has to be oil passages into the housing. You should try blowing the oil passages with compressed air. You may have to run a wire through them if they're plugged tight. It may just be sludge. Use your maximum air pressure.
Hal
Tommy D6-8U
10-29-2005 16:04:54
 Re: Cub Oiling Problem in reply to El Toro, 10-29-2005 14:03:25
Hal,
After a while I went back to it and found the passage leading to the filter housing. It is cross drilled between cyls. 3 & 4 from the tappet chamber through the main oil galley; there is a small pipe plug there.
It was plugged where it turned up into the filter housing. Cleaned and flushed it good and hope to get it back together soon. Thanks for your help!
El Toro
10-29-2005 16:19:31
 Re: Cub Oiling Problem in reply to Tommy D6-8U, 10-29-2005 16:04:54
Glad you found the problem. Those Cubs have a problem sometimes losing their oil pressure when changing the oil and it may occur at anytime. I would keep a close eye on the oil pressure when you start it. If you ever have that problem you need to remove that plug on the left side of tractor and squirt oil in there. You need to remove the oil filter cap and fill the housing with oil and replace the top.
This is the only Farmall that I've heard that does this. I think it's where the oil pump is installed at the rear of the engine. Most oil pumps whether on a tractor or car are connected
to the engine vertically and are submurged in the oil in the pan. Hal
