H rear wheel weight bolts
yooperdeere
11-06-2005 09:52:49
I was wondering what size bolts hold the rear wheel weights onto the rims??
El Toro
11-06-2005 13:14:54
 Re: H rear wheel weight bolts in reply to yooperdeere, 11-06-2005 09:52:49
Here's a web site for squarehead bolts. Hal
You can call or email: 1-800-327-6378 / iowa@earnestmachine.com
http://www.earnestmachine.com/bolts-square_head.htm
CNKS
11-06-2005 11:42:58
3/4 x 4 3/4 NC. These are square head bolts.
RustyFarmall
11-06-2005 11:49:32
 Re: H rear wheel weight bolts in reply to CNKS, 11-06-2005 11:42:58
Square head bolts are the "correct" bolts. In a pinch, hex heads will work just fine, and they will not rotate inside the hole.
Brian Schmidt
11-06-2005 15:54:38
 Re: H rear wheel weight bolts in reply to RustyFarmall, 11-06-2005 11:49:32
I disagree that the hex heads will not rotate. I have put on 13 sets and I always use hex head bolts as I am not after origional just some hardware to hold them on. Every one of them spun. You can easily wedge a screwdriver or punch in there to stop them. But, they will rotate.
Brent in IA
11-07-2005 04:10:10
 Re: H rear wheel weight bolts in reply to Brian Schmidt, 11-06-2005 15:54:38
Ditto....just did 2 sets and had to wedge a prybar in the back to keep them from turning.
RustyFarmall
11-07-2005 05:26:47
 Re: H rear wheel weight bolts in reply to Brent in IA, 11-07-2005 04:10:10
Mine did not spin, might be a difference in the weights, but I never had a problem.
CNKS
11-06-2005 11:52:10
They also cost less than square heads -- got mine from Marks Tractors, they weren't cheap.
