Farmall-A pedal guard image request
Kendog
11-09-2005 10:27:52
I am fabricating a Farmall-A pedal guard and need a side photo so as to nearly match the bend angles. If anyone has theirs off the tractor, and can provide a side view image, please post it or email me; ken@superfetch.com
Thank you. Ken
Hendrik
11-11-2005 00:30:58
 Re: Farmall-A pedal guard image request in reply to Kendog, 11-09-2005 10:27:52
I have mine off the tractor and could shoot a few digital pics of it. Email me if you are still in need.
Hendrik
scotty
11-09-2005 11:42:41
Ken, I know what your talking about, have one on my A and Super A but unfortunately dont have any pictures of them. If memory serves me well I think the sheetmetal is about 1/32" thk. The front side bolts to the operator platform then radiuses around the brake and clutch shaft and gets bolted up on the underside of the same platform. There are the slots for the pedals and a hole or two for the grease fittings. I would think if you had the op platform you could almost figure out the dimensions for that guard.
scotty
Kendog
11-09-2005 12:18:54
 Re: Farmall-A pedal guard image request in reply to scotty, 11-09-2005 11:42:41
I have the old one for the sheet metal template, but is so badly rotted and flattened I need a clean image to match the bends correctly.
HAS
11-09-2005 10:38:43
Check your E-Mail
Kendog
11-09-2005 10:57:50
 Re: Farmall-A pedal guard image request in reply to HAS, 11-09-2005 10:38:43
Thanks HAS but I may not have been clear. That's the foot-rest . I need the sheet metal & bend angles UNDER the pedals. Try again? Thank you!
CNKS
11-09-2005 12:47:29
 Re: Farmall-A pedal guard image request in reply to Kendog, 11-09-2005 10:57:50
Repro's of that part are available ---
HAS
11-09-2005 11:11:04
There's nothing under there on mine. There was nothing there on my previous A, nor on my B. It's just the petal shafts mounted to the under side of the floor plate.
