Spark Plugs for Farmall C
Vacherie
11-11-2005 15:31:52
I am replacing the Spark Plugs on my recently acquired C. It is a hobby tractor that will receive light use. What are some recommended plugs?
CNKS
11-11-2005 17:00:31
 Re: Spark Plugs for Farmall C in reply to Vacherie, 11-11-2005 15:31:52
I have never had problems with Champion plugs, or any other brand for that matter, I consider the major brands equal--heat range is more important, for a little used tractor get a heat range equivalent to a Champion D21, in other words hot. With no main jet adjustment, they typically run too rich, unless used a lot.
Vacherie
11-11-2005 21:16:20
 Re: Spark Plugs for Farmall C in reply to CNKS, 11-11-2005 17:00:31
Thanks for the info. It is recorded.
frmlljd43
11-11-2005 16:52:22
They originally came with Champion D-16's, but there are many other options out there today. I have had good luck with UD-16's, and I work and pull mine. a D-21 is a hotter plug, I run them in my A, works well in that one. Some say they foul, depends on one's luck. AC Delco has one, C87. They are a little hottor plug and my neighbors run them in their's and say they work good. I am not sure of the Autolite plug number, but the stores can give you that (or someone else here too), I just haven't had much luck with them, but others have. Any of those will work well for light use. Hope this helps. Good luck.
farmallguy3
11-11-2005 17:28:37
 Re: Spark Plugs for Farmall C in reply to frmlljd43, 11-11-2005 16:52:22
autolite 386 is the same size as champion d-21
PAULIH300
11-11-2005 15:51:51
Very controversial subject.Everyone has their favorite brand.I used Champion brand for almost a year in my 300U,but recently had to change them out because they were misfiring.I replaced the plugs that was in it when I bought it with those Champions (it was Champion that he had in it,and one was bad),but I have replaced them with Autolite.They seem to run very smoothly.....for now anyway.I find that Autolites keep firing no matter how carboned up they get.For a while.... lol
