TEARDROP TO SEALED BEAM LIGHTS, SUPER M SERIAL #
ronee
11-13-2005 23:01:07
ANYONE KNOW THE SERIAL # BREAK WHERE THE TEARDROP LIGHTS CHANGED TO THE SEALED BEAM LIGHTS ON A 1952 SUPER M? THANKS...
CNKS
11-14-2005 05:42:49
 Re: TEARDROP TO SEALED BEAM LIGHTS, SUPER M SERIA in reply to ronee, 11-13-2005 23:01:07
I believe 501 -- sealed beam lights were one of the features of the Super M.
john d
11-14-2005 16:15:12
 Re: TEARDROP TO SEALED BEAM LIGHTS, SUPER M SERIA in reply to CNKS, 11-14-2005 05:42:49
Not on my late '52 SM.
CNKS
11-14-2005 17:38:42
 Re: TEARDROP TO SEALED BEAM LIGHTS, SUPER M SERIA in reply to john d, 11-14-2005 16:15:12
John, that was intentional because I wasn't sure -- I worded it that way because I thought it would get disputed -- Ken Updike gave the right answer. I have a Stage 2 Super H with the new style, My parts manual does not show a teardrop, except for the rear light. The SH came out after after the Super M. Interestingly, the H parts manual also lists the new style, although they never left the factory that way.
Wardner
11-14-2005 00:51:13
My SM parts book does not give a changeover serial number. It has both lights listed. The actual date probably varied by assembly line and took several weeks or months to complete the changeover, depending on local stocks.
DWV
11-14-2005 06:42:50
 Re: TEARDROP TO SEALED BEAM LIGHTS, SUPER M SERIA in reply to Wardner, 11-14-2005 00:51:13
Wardner, don't know what printing of part book you have but have looked at this before.Where it shows the lights buy there self it doesn't say, but look at pics showing wireing and lights for tractors F-501 to F-28174 and L-500001 to L-504801
and it shows the teardrop lights.Look at the pics
for higher serial tractors and it shows sealed beam. So i'm saying the change is showed from stage 1 to stage 2.Don't know if that realy happend or not.
bermuda ken
11-14-2005 09:04:37
 Re: TEARDROP TO SEALED BEAM LIGHTS...CHANGES HERE in reply to DWV, 11-14-2005 06:42:50
The sealed beam (pie pan) style lights were used on the Super M's built serial number 28175(Farmall built) and 504802(Louisville built) and AFTER.
The parts book shows this as the headlight harness changes from the single wire (52973DA) to the two wire (358916R91) at these serial numbers. The headlights changed at the same time.
DWV
11-14-2005 09:31:10
 Re: TEARDROP TO SEALED BEAM LIGHTS...CHANGES HERE in reply to bermuda ken, 11-14-2005 09:04:37
Thanks,I should have ben a little more clear in my post.When i said look at picture,should have said picture and part # on lights to show which light was used.
