Draining a F-20 block
Jugger
11-15-2005 15:00:49
I would like to drain all the water from my f-20s block and radiator is there any place on the block to drain the water???
RAW in IA
11-15-2005 16:15:09
 Re: Draining a F-20 block in reply to Jugger, 11-15-2005 15:00:49
third party image
Make sure that it drains allthe water. Years ago dad pulled the cap off the pipe and walked away to let it drain, It didn't. Some rust plugged it and it froze and cracked the block. My brother had it welded years later when he restored it in shop class. Here is apicture of the job done. A cousin welded it andid a real good job. we had one little weep hole and plugged that with JB Weld.
russ hamm
11-15-2005 15:38:11
the drain tube on the left side under the radiator tank will drain the block as the lower radiator connection on the side of the block is downhill.early internationals will work that way except for w-30 f-30 w-40 and 22-36 as they have drains on the side of the block.dont know where you are but in kansas tonight this will be important info if she's got water in er.
