Farmall MD Clutch Questions
Matt Compton
11-16-2005 16:35:38
I have removed the hydraulic pump unit out of the MD to remove the clutch. To remove the clutch shaft, must I remove the clutch off the flywheel and take clutch and staft as one, or can the clutch shaft be removed seperately, I tryed sliding the clutch shaft back but right now it is against the trans shaft. The reason for removal is that the release bearing carrier shaft broke, is this common for these tractors, it looks like fairly poor material.
One more question, I bought the tractor and it had no starter. Didnt think it would be a big issue until I realized that it was a three bolt starter. Does anyone know if there is any other makes or model of starter that will fit, or will a 2 bolt starter off an M "fit" enough to make the engine turn over. Thank you for all your advice so far, Its been wonderful!!
Cheers Matt
Haas
11-16-2005 18:23:49
 Re: Farmall MD Clutch Questions in reply to Matt Compton, 11-16-2005 16:35:38
I don't think a starter from an M will fit the MD. One of the big suppliers of used tractor parts has starters for the MD listed in their catalog. It won't let me post with the name herein. The MD starter is a 12 volt starter, as all MDs were 12 volt, using two 6 volt batteries connected in series. To remove the clutch, remove the bolts that hold the clutch release carrier to the top of the housing. Remove the clamp bolts (You'll need to take loose all the external connections to the clutch) that hold the clutch release fork to the cross shaft. The fork is keyed to the cross shaft with two heavy washers located between the clamps and held in place by the bolts. Remove those washers. If there is anything else holding (I can't recall exactly) the cross shaft, take that loose. Now the cross shaft will slide out and you can remove the clutch fork. Take out three of the bolts that hold the clutch plate to the flywheel. Reinsert those bolts in the three holes in the clutch plate that had no bolt. Tighten those three bolts which compresses the clutch springs and releases it. Now unless I forgot something, the main drive shaft should tilt down enough to slide past the transmission coupling and be removed. Take the other three bolts out of clutch and remove it. I may have forgotten something as it has been a few years since I did this. The service manual says you can remove the clutch without removing the cross shaft. I got mine out without doing that, but I could not get it back in, so it's easier to just go ahead and take out the cross shaft. It's a dirty job down under there. If you have any questions, just send me an E mail.
