What type of oil to use in a BN?
Bilko
11-20-2005 16:01:47
I need to change the oil in my BN and was wondering what I should use? Thanks Mike
Bilko
11-22-2005 17:17:14
 Re: What type of oil to use in a BN? in reply to Bilko, 11-20-2005 16:01:47
Thanks for the answer's guys! Mike from MI
captaink
11-21-2005 11:32:58
My recommendation is for operating the tractor in temps below 0 degrees F 5W-20, for operating in temps between 0 and 50 degrees, either F 5W-30 or straight 10W. If you are operating the tractor in temps consistently above freezing 10W-30 or if you get extremely hot 15W-40 or straight 30W.
If you have a low oil pressure or oil consumption issues, heavier oil will mask the symptom, but won't cure the problem.
sammy the RED
11-21-2005 05:20:25
A good quality 10w30 will be just fine.
Dave BN
11-21-2005 04:41:10
Well, not much info to go on but I'll try to answer. Mine had detergent oil in it when I got it. I now use IH low ash 30W in summer and mix it 50/50 with IH 10W in winter. I seem to get better oil pressure with the IH oil. Does yours have detergent oil in it now? How cold does it get in winter where you live? I change the filter every time I change oil but not really sure this is necessary. Don't forget to dig the old O ring out of the groove before putting in the new one that comes with yur new filter. Sometimes they are really stuck in there. Dave.
BobOHIO
11-20-2005 20:07:30
I use straight 30 wt also in my BN.
Charles McNelly III
11-20-2005 17:57:36
I use HD-30 wt. in my B. Seems to work fine for me.
Charles McNelly III
11-20-2005 17:43:01
