Farmall Super H hydraulic's, loader cylinders
Mike S 806/H
11-23-2005 13:58:13
I put a Freeman loader on my Super H this summer, It lifts good but when you let it down watch out! its going down now! its even worse with weight in it. I have the cylinder hoses going to each side of the tractor belly pump. What a good fix for this? I bought a restrictor that flows one way and restricts the other,I was going to Tee the cylinders together with the restrictor in line, any better ideas?
Aces
11-23-2005 16:57:46
 Re: Farmall Super H hydraulic's, loader cylinders in reply to Mike S 806/H, 11-23-2005 13:58:13
Mike IH made a slow drop valve and a fast. The SH should have the slow but maybe some one changed it some time. With the slow you should be able to let it down as you wish.
matthies
11-23-2005 19:11:02
 Re: Farmall Super H hydraulic's, loader cylinders in reply to Aces, 11-23-2005 16:57:46
Aces are the slow valves available for the plain H or just the SH. thanks chris
Aces
11-24-2005 20:18:18
 Re: Farmall Super H hydraulic's, loader cylinders in reply to matthies, 11-23-2005 19:11:02
Matthies The patrs are the same from H M Sh SM SMTA belly pump and live HYD in the late Super's as I remember.
IaGary
11-23-2005 14:45:59
I'd say you need to rebuild the cylinders oil is leaking by the piston. Take the end cap off and pull the rams out remove nut on piston and the seals should come off. My idea aways.
IaGary
11-23-2005 14:49:10
 Re: Farmall Super H hydraulic's, loader cylinders in reply to IaGary, 11-23-2005 14:45:59
My bad. I misread your post the frist time. I thought is going down when setting idle. Sorry
