Steering Wheel Farmall H
Dave Miller
11-28-2005 07:05:56
whats the best way to pull off the steering wheel from a Farmall H.
fluggie in IA
11-28-2005 09:26:39
 Re: Steering Wheel Farmall H in reply to Dave Miller, 11-28-2005 07:05:56
If your not in a hurry, put a gear puller on it,crank it down as hard as you can then leave it over night or longer. usually they come loose "magically" overnight.
Curt Cooke
11-28-2005 07:20:12
Remove nut from end of shaft, heat the hub red with a torch, smack the hub with a heavy hammer rearward. If you havn't a torch remove the nut and smack with the hammer, it'll come off. Heat just makes it so much easier.
brainerd dave
11-28-2005 07:17:53
I had to use a small gear puller on mine. It came off very easily.
