What weight oil?
Jrry
11-28-2005 10:55:19
what weight oil is used for the hydraulics in a farmall 404? Mine is low and I could not find this in the manual. thanks, Jerry
El Toro
11-28-2005 11:18:20
 Re: What weight oil? in reply to Jrry, 11-28-2005 10:55:19
You should use Hytran hydraulic oil from Case/IH or Hygard from JD. Never let that reservoir run dry. That would ruin your hydraulic pump. Hal
Jrry
11-28-2005 11:29:18
 Re: What weight oil? in reply to El Toro, 11-28-2005 11:18:20
thanks for the information. I purchased the tractor with the fluid low. Just trying to get the tractor in good condition.
thanks, Jerry
