Generator for Farmall C
Dandy Don
12-07-2005 18:24:00
Hey guys, I brought a generator and don't know if it's 6 volt or 12 volt. The number on the tag is 1100501 OM26 if that helps any. It's a Delco-Remy and has a pully extended out like it would line the belt up on a Farmall C. Any help would be appreciated. I've learned alot on these boards thanks to you guys.
Don
Nebraska Cowman
12-08-2005 04:31:45
 Re: Generator for Farmall C in reply to Dandy Don, 12-07-2005 18:24:00
another helpful thing to remember DD, Delco color coded their tags, black tags are 6 V, red tags are 12.
Jim Becker
12-07-2005 19:20:07
That was the generator used on the earlier IH tractors (including the Super C) with a voltage regulator. It was used from something around 1950 to about 1953. The OM26 marking is a date code (in this case I semi-guess it to be 12/26/1950).
Bob
12-07-2005 19:02:09
Google "Delco 1100501", and you'll find out it's a 6-Volt generator. (Unless somebody swapped out the "guts", and left the tag.)
