Farmall axle parts source needed
3/4 ton
12-10-2005 04:15:14
My neighbor (in Va.) needs a source for a replacement kingpin on wide front axle on Farmall M. He broke part of the axle assembly when he hit a hole unexpectedly with the right front wheel.
Can any reccomend a Farmall Parts source for him to write or call. At the moment, He is grounded.
Thank you
farmallhal
12-10-2005 06:08:18
 Re: Farmall axle parts source needed in reply to 3/4 ton, 12-10-2005 04:15:14
Might try Carter & Gruenewald in Wisconsin-phone 1-866-FARMALL (327-6255). Have seen lots of good comments above their knowledge and service. Brumuda Ken might see this post and post a response. If the front end is by someone other then IH you will probably need to try and contact the original maker. Good luck, Hal
Boyd G
12-10-2005 06:02:14
You might try Bates Corp in Bourbon IN. 1-800-248-2955. They are all IH.
Boyd
