Will a Model 31 Loader fit on a 400?
Troy (MI)
12-17-2005 13:35:10
I have a model 31 loader that is currently on my M. It has a blade on it for snow removel and it does a great job. I would like to put it on my 400 so that I can take advantage of the live hydraulics. Does anyone know if the loader will fit on a 400? I have measured the wheelbase of both tractors and if I am right, the 400 is about 4" longer. Has anyone ever tried this? Just thought I'd ask before I spend half a day and find that it won't work. Thanks for any help.
Brownie 45
12-18-2005 03:58:23
 Re: Will a Model 31 Loader fit on a 400? in reply to Troy (MI), 12-17-2005 13:35:10
WE have had a loader on our SMTA for over 40 years & made oak blocks to put between the loader frame & axle housings. Use a table saw to make the "tongue & groove" on the front & back of the blocks. WE made longer bolts from readi-bolt material. All other bolts fit perfectly on the front end mounting brackets.
Hugh MacKay
12-17-2005 14:39:27
Troy: My dad moved a model 31 loader from an H to a 300 and yes the difference was 4". They fabricated a 4" spacer to go between loader frame and tractor axle housings. Also took a bit of fabrication to mount that standard out front of grill for the guide pipes to slide through. That was the only changes needed.
RustyFarmall
12-17-2005 14:35:22
Yes, it will work, but you will have to fabricate a 4 inch spacer to fit between the axle on the 400 and the loader mount. That spacer is an IH item but I don't know the part number. Years ago when my dad traded his M for a brand new 350 the dealer came up with the spacers so the #31 loader could be used on the longer 350.
