450 electrical system
dej(JED)
12-19-2005 09:45:25
Did the 450 gasoline tractor come with a 12 volt system? If so is it a positive or negative ground 12 volt system.
randy hall
12-19-2005 10:55:19
 Re: 450 electrical system in reply to dej(JED), 12-19-2005 09:45:25
450 gas tractors after #11083 came with twelve volt systems and like dave said they are positive ground.
Dave Slater
12-19-2005 11:10:48
 Re: 450 electrical system in reply to randy hall, 12-19-2005 10:55:19
Randy that replacement block that I posted about
a while back with 67 date code and C-248 cast on it contained 4 1/8 pistons and sleeves. Dave
DWV
12-19-2005 10:45:48
After a certain serial # the gas came with 12 volts and positive ground.
old
12-19-2005 10:36:44
I think it came out with a 6 volt system and + ground, but many have been changed to 12 volts.
