Re: Rear wheel seal on 350
350 HU Don
12-28-2005 05:47:27
No problem handling the wheel and tire assembly. I've had that off this tractor a couple of times and grew up on H's and 300's and like you, we moved the wheels for different purposes so I've had plenty of experience with wheels. I'm just concerned about whether I can reach the seal from the outside. I sure do appreciate all the good advice you guys give.
Allan in NE
12-28-2005 07:08:56
 Re: Rear wheel seal on 350 in reply to 350 HU Don, 12-28-2005 05:47:27
Yes Sir,
The seal is pressed in "backwards" in that outter cap that is held on with four little 3/8" bolts.
Then there is an o-ring around the inner centering lip of the seal which seals the cap itself.
Before you loosen the cap, see if there is any "shake" in the axle. That will tell you if the bearing is good or not.
Also, a couple of gallons of hytran is gonna pour out so have a catch bucket at the ready. :>)
Allan
350 HU Don
12-28-2005 15:53:52
 Re: Rear wheel seal on 350 in reply to Allan in NE, 12-28-2005 07:08:56
I've checked the axle, no wiggle so I think the bearing is good. I will now pull the wheel and the axle end cap and see what I find. Thanks again for your help. You guys are great!
