Thanks CNKS NAT2
stu in njo
01-03-2006 07:54:54
I have 2Hs and nether one starts good the sc is worn out and it starts in 2-3 revs. Nat I have done the things on youre list a few times plus had starter checked out replaced starter&ignition switches.If you can think of something more I mised let me know please!
Brownie 45
01-04-2006 05:40:43
 Re: Thanks CNKS NAT2 in reply to stu in njo, 01-03-2006 07:54:54
Be certain that your battery cables are in excellent shape. The neighbor down the road had an M that wouldn't crank over very fast. After cranking for 5-6 seconds, I felt the batt. cable ends to see if they were warm. The end going to the starter was hot, as well as the end attached to the pushbutton starting switch. These were original cables. I cut off the ends and soldered new terminal lugs onto the cables. The M cranked normally after doing this. Worth a look Maybe ?
stu in njo
01-03-2006 12:09:47
 Re: Thanks CNKS NAT2 JIM N in reply to stu in njo, 01-03-2006 07:54:54
I have done all the things on your list! the h cranks slow with a weak spark. I'm thinking of puting a 8v battery and or electronic ignition.I have turned a wrench most of my 60yrs and can't get the 2 hs to start good! Most of the time I just pull them they start right up.
gene bender
01-04-2006 12:48:32
 Re: Thanks CNKS NAT2 JIM N in reply to stu in njo, 01-03-2006 12:09:47
I f they start that good a 8v will probably foot the bill.
gene bender
01-03-2006 15:55:40
Tha 8v is a good quick fix stay with pos ground and no need to do anything else. This has been done for many many years and it just works. The batts can be found at any CAR QUEST and fit in the original batt boxes just fine.
Janicholson
01-03-2006 14:26:43
If they are users, and not lookers, change them to 12v. I like mitsubishi alternators small compact and reasonable cost, internal regulators. They and all alternators (to be found easily) are neg ground.
Bob M has wiring diagrams (see archives).
Putting 5-30 oil in it will also help drastically in cold weather. 15-40 in summer.
Try a higher CCA 6v. battery. 650 or more THey do not usually cause your grief.
Keep us informed on your outcome,
JimN
stu in njo
01-03-2006 14:43:49
 Re: Thanks CNKS NAT2 JIM N in reply to Janicholson, 01-03-2006 14:26:43
Ther users I gess its time to go 12v Thanks Stu.
JANICHOLSON
01-03-2006 09:45:44
Though I'm not sure what you have done my list includes:
#1 (or fatter) battery cables
Good plugs
Battery check for weak cell
Good points/condenser (never replace a good condenser, they don't wear, they fail).
correct carb adjustment
Operating choke.
Good luck, JimN
