M three point hitch
blocks
01-23-2006 16:48:36
Last summer I bought a hitch a seen while traveling down state. The guy said it wae off an M so I gave him $80 he was asking it came with the hydraulic cylinder. Went to the cabin up north where I leave the M and found out it did not fit it look's like it would put the distance from where the hitch bolts on to where the top link bracket goes acrost is not off set enough to clear it look's like about 4''. Is it maybe for an H and not an M thanks Dennis in MI
CNKS
01-23-2006 17:04:52
 Re: M three point hitch in reply to blocks, 01-23-2006 16:48:36
The same hitch will fit a C, H, or M, or at least Saginaws will -- probably just a low quality hitch. Saginaw does make a different hitch for the C, as it does not need to be quite as heavy duty as the one for the H/M; their H and M hitches are the same and can be used at least thru the 450.
