i need help ordering a bearing set!
Booe
01-28-2006 09:58:29
alright well i am getting ready to order a set of main bearings and rod bearings for my 45 m. the bearings themselevs say std. but i was curious what i need to order the only serial numbers i could find were one on the id plate that said 7702 and one on the engine itself taht sais 6722-DH. and the main bearing sais 45630 DA but below that it sais 12 1 SM. not sure why it would say sm because its not a super m. thanks alot
El Toro
01-28-2006 11:54:35
 Re: i need help ordering a bearing set! in reply to Booe, 01-28-2006 09:58:29
I would agree with old on having that shaft checked at your local auto machine shop. Would be a good time to have new cam bearings installed too. It's for having good oil pressure. Hal
Andy Martin
01-28-2006 10:42:15
The second best way is to order a set of bearings and plastigage them after installation to make sure they're OK.
Do the old bearings look OK?
If so plastigage them first to see what you've got.
Do the journals look GREAT?
It is best to have the crank checked but I have been very successful putting bearings in, plastigage, and go but I work my tractors, they are not for show.
Booe
01-28-2006 10:51:01
 Re: i need help ordering a bearing set! in reply to Andy Martin, 01-28-2006 10:42:15
i really dont want to pull the crank out but it does look great. there is a thin scratch in 2 of the rod journals but nothing major. i can probably clean those up pretty well. the mains look great. but the main bearings show some wear and have a couple chips out of one. and the rod bearings have some pitting. i wont show this tractor. its more for sentimental value and occasional mowing. thanks for your help
old
01-28-2006 10:02:26
Best way to do it is to take the crank to a good machine shop and have it checked. That way you know what size it is and if its true and not out of round. A good machine shop can then order the right bearings for it.
