Calling Dave Slater
Tim Shaw
01-31-2006 10:24:54
I stopped by the shop that is adding the power steering to the 350. They said that the inside remote from the donor tractor had a plug in the bottom port. They can only get the power steering to work if they hold back on a hydraulic lever. They are going to disassemble the priority valve today and check it out. Have any other ideas?
Thanks, TS
Tim Shaw
01-31-2006 15:53:47
 Re: Calling Dave Slater in reply to Tim Shaw, 01-31-2006 10:24:54
Thanks again!
TS
Dave Slater
01-31-2006 11:55:19
There on right track,the priority valve may have to much wear in the piston to bore area or something else wrong in there.When valve is held
it forces more oil pressure to steering.If steering is not to weak and piston or bore is worn, sometimes you can drill the hole in center of piston a little at a time and get it to work.Keep record of starting hole size incase it needs filled in and drilled agian if other repairs are made.
Dave Slater
01-31-2006 15:10:19
 Re: Calling Dave Slater in reply to Dave Slater, 01-31-2006 11:55:19
Should have mentioned checking pump pressure just to make sure its okay before other changes.
