Dag nabbit. I knew I shouldnt have done that.
Kelly C
02-03-2006 05:51:44
When I put the new rear main oil seal in my 300. It was the 1st one I had ever done.
That new seal looked a little long so I trimmed a bit off to make it fit.
Guess where I have oil drippin?
Dummy me.
I now know it get compresses when you tighten the halfs back together.
Who ever it was that said ignorance was bliss. Didnt see my oil puddle.
Brownie 45
02-05-2006 11:28:22
 Re: Dag nabbit. I knew I shouldnt have done that. in reply to Kelly C, 02-03-2006 05:51:44
The neighbor down the road always said "If it doesn't leak more than 5 gallons a day, it doesn't need fixed". Oil leaks can be aggravating. Good luck.
russ hamm
02-03-2006 16:18:26
kelly, i always said if ignorance was bliss i should be the happiest man alive! hang in there.russ
Aces
02-03-2006 08:32:27
Kelly You should not have cut any off, the other thing what where the aluminum plates like. Many times they are warped and need replaced. I always put the felt in dry then oil other wise they swell and are harder to install.
Kelly C
02-03-2006 11:01:58
 Re: Dag nabbit. I knew I shouldnt have done that. in reply to Aces, 02-03-2006 08:32:27
third party image
"Kelly You should not have cut any off"
Yup.....ya I sure did.
I remeber looking at it and thinking. " There is no way that big peice of felt is going to fit that."
After I learned on my 400 that the 2 cap screws that hold the 2 halfs together. Draw that felt in nice and tight around the shaft.
Just on here to pay penance and knock my self in the head. I could have easly fixed this before I put the motor back on my 300. Didnt even dawn on me.
the tractor vet
02-03-2006 06:59:51
Kelly them old rope seals should be soaked in oil for atleast a half a day before they are installed and then ya sorta roll them in if ya don"t have the tool to drive them into place . The tool looks like a half moon with a drive handel on it to form it to the saddel then there is vary littel to trim off and a there must be a littel to stick out on both the cap and block to make the seal .
RustyFarmall
02-03-2006 05:54:09
That 300 is just marking it's territory.
Kelly C
02-03-2006 06:04:45
 Re: Dag nabbit. I knew I shouldnt have done that. in reply to RustyFarmall, 02-03-2006 05:54:09
Then why does the oil spots spell Dummy in the snow if left in one spot.
Oh well. After splitting my 400 and my 706. Splitting my 300 will be like a tinker toy now.
RustyFarmall
02-03-2006 06:21:32
 Re: Dag nabbit. I knew I shouldnt have done that. in reply to Kelly C, 02-03-2006 06:04:45
Sounds like your 300 must be quite talented, none of my tractors know how to spell, but most of them still insist on marking their territory.
