Torque amplifier repair?
Tired 300 in Mn
02-12-2006 17:11:15
I have my 300 apart to repair some oil leaks, & rebuild the front bolster. The torque amplifier is dead, & I'm trying to decide whether or not to repair it. I'm told that the rollers eventually wear flat, & will no longer hold when TA is used. The local IHC dealer sells a ramp with new rollers, & a planet carrier in which you install your planetary gears into. Is it possible and practical to replace springs, pins, & rollers in my ramp assembly & save some money? If my terminology is off, I apologize. Also, if I sound cheap, I probably am, but this is a loader tractor, and probably will not ever pull a plow or a hay baler. Thanks in advance for any help, I don't post often, but I enjoy this forum.
MagMan
02-13-2006 12:37:48
 Re: Torque amplifier repair? in reply to Tired 300 in Mn, 02-12-2006 17:11:15
If you are interested in this let me know. I may be able to work with you on the core charge. JON
Ramp Assy., Bearing Carrier & Overrunning Clutch Sugg Retail: $117.45 Core Charge: $20.00 Package Qty: Weight: 6.00 lbs
Tired 300 in Mn
02-14-2006 09:44:25
 Re: Torque amplifier repair? in reply to MagMan, 02-13-2006 12:37:48
Thanks MagMan, once I get the unit apart, I may want to talk to you.
Mike S 806/H
02-13-2006 11:54:37
I just did a TA in a 450 Farmall , got all the parts from CaseIH dealer, springs,pins,and rollers, If I rember right the rollers are around $1.80ea, pins $3.00ea and springs $4.00ea,
Tired 300 in Mn
02-13-2006 07:29:18
Thanks for the info, I'll post again when I get the unit out & disassembled.
Don L C
02-12-2006 19:55:50
Yaa got her apart fix it right.....
Hayfarmer
02-12-2006 18:54:47
When I replaced the ramp and roller setup on my SMTA the rollers looked fine, they had pushed into the ramp setup and crushed the bottoms of the track so the pins and springs wouldn't work. I doubt the rollers wear that much as they are the hardest metal. I used the old carrier setup and just changed the ramp and rollers. Depends upon what all is bad. You'll need to look at the T/A clutch also.
Larry806
02-12-2006 18:52:45
I went through 3 torque's week before last SMTA , 400 & SMTA D the most I had in one was 165.00. You can get the rubber plugs , springs, and pins from a IH dealer. The rollers aren't available. Tractor Vet said you can get them from Timken I got lucky & found some NOS. When you order the gasket & seal kit ( Hy Capacity) you have to order two other gaskets I can get the part number if you need it ( both the same)
2 of them had the nut that holds the TA flywheel backed off the locking tab had broken. I went ahead & went through the ramp & rollers anyway while I was in there
Levi K
02-12-2006 18:28:51
Yeah right now I am watching the T/A repair video from this website. And tonight we just split my 300 to fix the T/A. Sp I don't know what to do, I'm in the same boat you are.
PAULIH300
02-12-2006 18:31:56
 Re: Torque amplifier repair? in reply to Levi K, 02-12-2006 18:28:51
One thing bothers me about that video....all those plaid shirts...Reminds me of Dinty Moore. lol
Otherwise,those videos are pretty insightful.
Don L C
02-12-2006 20:01:23
 Re: Torque amplifier repair? in reply to PAULIH300, 02-12-2006 18:31:56
Yea----maybe thoes guys know what they are doing..... but work under dirty conditions.....like touching bearing surfaces with dirty fingers....no way.
Bobcat
02-12-2006 17:36:38
I am all for saving money too! But by the time you buy your carrier, ramp and roller set from I.H. you will be about the same $Moneys$ as a rebuilt with heavy sprag from "Steel Wheel Ranch" give Mike a call you will be glad you did!
scotc
02-12-2006 18:58:50
 Re: Torque amplifier repair? in reply to Bobcat, 02-12-2006 17:36:38
I know there's contact info on this site somewhere where is it I need to put one in the 400.
Bobcat
02-13-2006 06:41:58
 Re: Torque amplifier repair? in reply to scotc, 02-12-2006 18:58:50
"Steel Wheel Ranch" Everest Ks. 785-548-7437
