H live hyd
garyj
03-05-2006 17:54:42
Ihave a live power hyd pump off a 350,will it bolt up to my H.
Nat 2
03-06-2006 05:39:24
 Re: H live hyd in reply to garyj, 03-05-2006 17:54:42
What QR should have said is, YES, but only if you have an H made after 1950 that has the newer design front cover and timing geartrain. Otherwise, it won't fit unless you swap out the front cover on the engine, along with the cam gear.
Quebec Red
03-06-2006 18:05:42
 Re: H live hyd in reply to Nat 2, 03-06-2006 05:39:24
I lied. It was 27 years ago. Sorry that I missed a couple of details, but I think that they would be self evident. Anyway, thanks for proofing my post!!!!!...QR..
Quebec Red
03-05-2006 18:09:10
Short answer--YES-- . Now for the serious stuff. I did this trick 25 or more years ago. I had a scrapped 300. I took the front engine plate and timing gears (they are heavier) and away I went maybe some small details omitted, but you should change the gears as the H gears will fail if you use the hyds much (and you will). Makes the H a h-ll of a lot more useful and saves your leg and the clutch. ...QR..
Jim J
03-05-2006 20:12:04
 Re: H live hyd in reply to Quebec Red, 03-05-2006 18:09:10
The only gear that is heaver is the cam gear.
