SW6 serial # location
JaredM
03-18-2006 06:48:58
I need to know where the serial number tag should be located on a Super W6. If it"s not there anymore how do I tell the year. Is there such thing as an early or late SW6. Thanks for any replies. JaredM
Quebec Red
03-18-2006 09:05:24
 Re: SW6 serial # location in reply to JaredM, 03-18-2006 06:48:58
Should be a plate riveted onto the left side of the clutch compartment. There were 3 Stages of SW-6. All had the 264 motor and faster 2,3,and 4th gears over the W-6. The first Stage was basically only those improvements as disc brakes were on the last W-6s. The Stage 2 had a channel frame and 18 inch front tires. They, along with late Stage 1 had sealed beam lights. The late Stage 2 had the newer seat with the undermounted spring and shock. The Stage 3 had major changes. Like a Torque Amplifier and Independent PTO, along with revamped controls-throttle, choke and starter, longer wheelbase and hood. There are proably other changes that I am omitting; after all the last SW-6TA was produced in November, 1954. More questions, just post here!.....QR..
JaredM
03-18-2006 09:37:45
 Re: SW6 serial # location in reply to Quebec Red, 03-18-2006 09:05:24
So ours must be the stage 2 because it has the seat with spring and it has independent PTO thanks to an M&W hand clutch not a factory option. So what years were the stage 2 made and if it was split early and late where would you put it. I need to know because I need a new wiring harness and the cheapest place"s catalog says there is an early SW6 seial numbers 501-3950 and then they have another just listed as SW6. Thanks for the help. JaredM
Quebec Red
03-18-2006 10:52:11
 Re: SW6 serial # location in reply to JaredM, 03-18-2006 09:37:45
My source does not specify specific serial number breaks other than by year, which are as follows:501-2907 are 1952s; 2908-8996 are 53s; any higher are 54s. I would suggest that the seat could have been replaced; the M and W PTO is an axle declutch giving live PTO, a big improvement over the transmission PTO. Is your M and W PTO lever on the left side? Also front wheels could have been changed from 16`to 18`over the years. Is the front belley frame is U shaped without slots along the side, or is it a channel style with oval holes, similar to a Farmall H-56 series? The U shaped frame would date it as a Stage 1, unless somebody got really ambitious and swapped. Anything is possible, and they would interchange, but I would much rather put my time towards chasing females than switching frames....ya know....??? Hope this helps...QR..
