Could someone educate me?
chadd
03-23-2006 11:58:50
I was discussing tractors with some guys and they weren't exactly impressed with horsepower ratings of 36 horsepower for an M. They claimed that then their riced Hondas could outpull a tractor if placed in the right chassis.(I don't picture that combination lasting long at load:) I then told them that horsepower isn't really the pertinent number here, and that torque is more important. I know that HP=(Torque x RPM)/5252. Does that equation apply here? So if it does, does that mean a 105 horsepower Farmall 806 at 2400 rpm makes 229.78 lb/ft of torque? Does gearing account for the rest? Would one of you guys mind enlightening me? I want to make sure I am telling these guys truth. This just proves they don't teach us everything in college:) Thanks.
KEB
03-23-2006 19:46:27
 Re: Could someone educate me? in reply to chadd, 03-23-2006 11:58:50
Alright guys, here's the deal...
For the sake of this discussion we'll ignore losses in gearing & bearings.
Horsepower is horsepower, period. Torque is a measure of the rotational force available at the measurement point. How much power (the rate of doing work) is available is a function of the torque and the rotational speed (i.e., HP = torque x RPM x constant).
If you were to take a ricer engine making 100 HP at 6000 RPM, and put a reduction gear on the end of it to reduce the speed to 1600 RPM, it would make exactly the same torque as a 100 HP tractor engine turning at 1600 RPM. If you were to then drop this ricer assembly into a tractor frame so that it had equivalent weight (& therefore traction), it could in fact pull the same load as the same tractor with a 100 HP tractor engine.
How long it would last under those conditions is a whole 'nuther issue, which we won't go into here.
Remember, when you change speeds via gearing (and ignoring losses) the torque is multiplied by the inverse of the speed ratio. For example, a 100 HP engine at 6000 RPM is producing 87.5 ft-lbs of torque. If we gear this down to 1600 RPM, we now have 328 ft-lbs of torque and our original 100 HP available at the output shaft. Works the same way in reverse, if we were to take our 100 HP tractor engine, and run our reduction gear in reverse to produce a shaft speed of 6,000 RPM, we would now have 87.5 ft-lbs of torque and 100 HP available at the output shaft.
The big difference between tractor and car engines (besides the fact that a tractor engine will last many time longer than a car engine) is that tractor engines are made to produce maximum power at a constant or very narrow RPM range, whereas car engines are made to produce power over a wide RPM range. Additionally, there is an advantage to having a heavy tractor engine, and there is an advantage to having a light car engine. I'm sure there are other design considerations as well, but these two come to mind quickly.
The difference in pulling power between a tractor and a rice burner is a function of gearing, weight, and traction. If you took a rice burner, geared it down to where its top speed was 4 miles per hour, and could get unlimited traction with those silly little tires, it would in fact pull what a tractor with equivalent horsepower can pull at 4 mph, also assuming unlimited traction.
The reality of the situation is that a tractor is designed for pulling, and a car is designed for speed, and there really isn't an apples to apples comparison between them.
Now if we could just convince the younger generation to get rid of the ricers & go back to good old american iron, we might get somewhere.
Keith
KEB
03-23-2006 20:09:45
 Re: Could someone educate me? in reply to KEB, 03-23-2006 19:46:27
Almost forgot...can someone explain to me why my Farmall H rated at 25 drawbar HP can pull a 4 ft box scraper with the rippers down and the box full of dirt without batting an eye, and my "27 HP" lawn tractor has trouble pushing a small blade through snow. I'll give the lawn tractor something for losses in the hydrostatic transmission, but I strongly suspect there's a lot of horsepower inflation going on in rating lawn & garden equipment. Wonder if anyone has ever put one of these lawn tractors on a dyno?
RN
03-23-2006 20:54:53
 Re: Could someone educate me? in reply to KEB, 03-23-2006 20:09:45
H weighs about 4000 lbs. Garden tractor weighs less than 1000 lbs. Tire contact patch H tire 11.2 by 38 is bigger than garden tractor maybe 8 x 16?. H has more traction, can pull more. Garden tractor 27 hp is probably rated peak hp at engine flywheel, deduct 10-15% for loss through transmission, rearend to tires. As previously noted H rating is drawbar, actual pulling power. RN
John M
03-23-2006 17:31:48
Just remind them that when their little piece of crap Jap built pile of junk is sitting in China awaitng recycling, your M will still be there running!
Steven@AZ
03-23-2006 14:27:47
Horsepower is the amount of work that can be done over a certain period of time. Torque is a static force that doesn't require movement...
I believe a Farmall M has in the neighborhood of 300 lb-ft of torque.
Torque vs HP 1
Torque vs. HP 2
Duane WI
03-23-2006 13:43:34
Another thing to consider is that a tractor is designed to put out max horsepower on a continous basis and last for years. Car and motorcycle engines are rated at peak horsepower but none of them would stand up to putting out peak horsepower continously day in day out.
RN
03-23-2006 13:19:46
M hp rated at 1650 to 2000 rpm. Hondas hp rated at 6000 rpm, varies a bit. Drawbar/wheel hp differs from flywheel SAE rating about 10-15% roughly. DIN ratings are about 5-10% less than SAE. Advertised hp tends to be highest that can be claimed for advertising purposes- check some areas that tax by hp a see what is claimed. Working hp is what can be actually used to pull or turn PTO. Note on car hp- wheel hp has been a standard for past few years- truth in advertising laws most places. RN
Red Dave
03-23-2006 12:44:14
That 36 horsepower listed for an M is whole different breed of ponies than the ones they put in cars. The M horsepower is it's ability to do a certain amount of work, in a field, over a specific amout of time. It's not just engine power, traction enters into it too.
There's a couple around here that give me the same crap about tractor horsepower. I tell that I have a chain, come on over and hook-up. They generally scatter like cockroaches then.
Harold H
03-23-2006 12:20:05
Horse power isn't all it is about. A UD-18A IH power unit rated 125 HP will run a four stand cotton gin 24 hours a day. Try that with a 400 plus HP Chevy V8. The Chevy wouldn't even start to turn all the shafts under load. Hook your Farmall M to a chisle plow and see how deep it will pull it. Unhitch it from the M and see how deep his Honda rice rocket will pull the same chisle plow (or disk or any other implement sized for the M). Also ask him how well his Honda rice rocket will be pulling sixty or so years from now.
Harold H
mcraig
03-23-2006 12:08:05
Just a quick note. Tractor hp is measured at the drawbar. On cars, the engine only is measured. That's a net to gross comparison.
RustyFarmall
03-23-2006 12:18:14
 Re: Could someone educate me? in reply to mcraig, 03-23-2006 12:08:05
Exactly, if you measured the output of the Farmall M at the flywheel, which is where those Hondas are measured at, you would see a big difference.
chadd
03-23-2006 12:56:27
 Re: Could someone educate me? in reply to RustyFarmall, 03-23-2006 12:18:14
Has anyone ever tried running a tractor motor on a crank dyno?
BillyinStoughton
03-23-2006 13:21:00
 Re: Could someone educate me? in reply to chadd, 03-23-2006 12:56:27
I have run a tractor motor on an engine dyno and come up with concrete numbers in the past. Everything is still relative though. I had an overbore kit, 350 cam, and E-12 carb on a C152 and put up 34.2 HP at Engleking's in Rock City, IL...what does that mean?...maybe I pull two bottoms a little bit easier...but the H is still a two bottom tractor.
As far as the fart can Honda argument? It surely makes enough power to perform useful work, it however doesn't employ enough mass or traction to do so. It's the apples to oranges thing. One is going for transportation and MPG, the other for yield to the acre.
Billy
chadd
03-23-2006 13:40:32
 Re: Could someone educate me? in reply to BillyinStoughton, 03-23-2006 13:21:00
For a tractor though, isn't torque more important? Isn't it torque that is used to get a large heavy load moving? If the Honda engine were able to be bolted into a tractor chassis, its 175 horsepower wouldn't really be usable would it? It only would have like 85 ft.lb of torque, which would mean it would just stall when a heavy load was applied to it, wouldn't it? Wouldn't you need to dump the clutch at like 7000 rpm to get it in the power band, and then wouldn't it cook the clutch instead of moving? Just out of curosity, what kind of torque did your C152 make on the dyno? I would think it would be a lot higher than that of a car.
BillyinStoughton
03-23-2006 13:56:32
 Re: Could someone educate me? in reply to chadd, 03-23-2006 13:40:32
If I remember correctly it was just a tick over the three digit mark...102 and some change I believe. I could dig up the dyno sheet and verify that yet. For some reason I keep my dyno sheets like that favorite old concert shirt ya just can't get rid of. Ha ha ha!
Billy
chadd
03-23-2006 12:15:51
That is a good point... I forgot about that one. This might be a dumb question, but don't they also have chassis dynos for cars? I know the factories don't use them for their published numbers, but don't hot rodders use chassis dynos? (I am not trying to be a devil's advocate here, just genuinely curious)
Tim...Ok
03-23-2006 15:50:37
 chassis dyno in reply to chadd, 03-23-2006 12:15:51
Yeah,the chassis rigs are widely used,the factory quit using the crankshaft numbers in about 1972 or 73,I forget which..so all numbers you see on a car today are at the tires..my lil ol' chevy pickup put 538hp to the rear tires without the nitrous :)
Tim
RustyFarmall
03-23-2006 14:15:47
 Re: Could someone educate me? in reply to chadd, 03-23-2006 12:15:51
Just for the record, the first car I owned was a 1960 Chevrolet complete with 283 cubic inch V8 and powerglide tranny. I slightly built the engine using a 4 bbl, carb and intake, swapped out the original heads for the power pack heads, and added dual exhaust. The car ran pretty decent. I was in auto mechanics school at the time, and we had a chassis dyno, so naturally I had to try it. According to the books we had, the engine I had should have been putting out just under 200 HP. The best run on the dyno indicated a lowly 60 HP being put to the road.
