Steel wheel rims?
kevin Ruppert
03-31-2006 12:32:22
Looking for steel rims for a Farmall f-20 with steel lugs to be able to drive on roads.
Turk
03-31-2006 13:54:56
 Re: Steel wheel rims? in reply to kevin Ruppert, 03-31-2006 12:32:22
Original hay bands are a little hard to find. Mine are a rolled 'T' iron, and they bolt on the side of the lugs and slip over the tops of the lugs. A serious steel shop may be able to roll some for you, I have had 1 1/4 front skid rings rolled out of angle iron. Thought I was going to sneak up on a pair of 'em for a JD at an auction once, nobody even seemed to notice them. They ended up bringing $1200.
Janicholson
03-31-2006 12:39:11
Have a steel shop make two loops the circumference of your lug tips, wide enough to cover the lugs out of 1/2" stock. At the gap use small load binders to clamp tight. If the lug spacing is wide (more than 6") i would screw blocks of wood between lugs to prevent crushing the hoop. Welded on tabs keep it centered on the wheels.
JimN
