BLEEDING HYDRAULIC CYLS.
john-wiz-
04-07-2006 05:39:25
I have a loader on my "H" with a live pumps system and I cannot seem to remove the air in the cylinders. every time I lift the bucket up, I can jump up and down in the bucket and the cylinders go in and out (spongy) any idea how to remove the air???? I have tried to fill the cylinders before putting them on the machine but the results are still the same - please help
Hugh MacKay
04-08-2006 02:57:48
 Re: BLEEDING HYDRAULIC CYLS. in reply to john-wiz-, 04-07-2006 05:39:25
John: I think Paul has it nailed. Often times this problem can cause the resovoir to over fill and belch the fluid out on the ground. Probably not bad on a tractor.
Truck dump hoists will do this, some of those big telescoping cylinders on trailers often have as much fluid left in the cylinder, when completely down, as there is in the resovoir. If you leave it in the down position it will all drain back. Those have air bleeders on top end of cylinder. Most have a spring loaded down position, making it such, that you must hold it in that position. Dump trucks can belch out 5+ gallons of oil if this is forgotten.
PAULIH300
04-07-2006 09:42:44
What I find happens with single acting cylinders,is when you let them down (by gravity) and you leave the lever in that position after the loader touches the ground,it emptys the cylinders completely.Then,the next time you power them upward,they have to be re filled trapping a pocket of air (a void).And that keeps happening again and again.Best advice? Dont let the lever stay in the down position any longer than it needs to be.
john-wiz-
04-07-2006 10:43:20
 Re: BLEEDING HYDRAULIC CYLS. in reply to PAULIH300, 04-07-2006 09:42:44
GOOD POINT - I will try that on Sat.
Thanks
Janicholson
04-07-2006 06:34:40
With engine off, and the pressure in the hyd system at zero, remove the cylinders (one at a time, block and be safe here) then position the cylinder so that the inlet fitting is highest. Loosen the fitting and push in on the ram to displace air. Tighten, then repeat on the other side.
Good luck, JimN
Dellbertt
04-07-2006 06:06:07
I just change two hoses on rear lift and it had some air. After a couple days of working it the air seem to work its way out. If yours is a vented system with no leaks it should work itself out with full travel use.
john-wiz-
04-07-2006 06:16:53
 Re: BLEEDING HYDRAULIC CYLS. in reply to Dellbertt, 04-07-2006 06:06:07
my cylinders are only single action and i do not see any vents. it was always spongy so that is why i re-built the system hoping to stop this - but it is still spongy
Dellbertt
04-07-2006 12:32:19
 Re: BLEEDING HYDRAULIC CYLS. in reply to john-wiz-, 04-07-2006 06:16:53
The vent is usually in the resevoir.
RustyFarmall
04-07-2006 06:32:13
What kind of loader is it?
john-wiz-
04-07-2006 07:00:12
 Re: BLEEDING HYDRAULIC CYLS. in reply to RustyFarmall, 04-07-2006 06:32:13
i think it is a model 33 IH loader
RustyFarmall
04-07-2006 07:51:01
 Re: BLEEDING HYDRAULIC CYLS. in reply to john-wiz-, 04-07-2006 07:00:12
Sorry, I am not familiar enough with that model to have any real insight, but the others have provided some good hints.
