Farmall Model A hydraulic pump
Jim DeChambeau
04-17-2006 13:06:35
I have a question that I hope someone can answer. I just purchased my 1st. Farmall tractor. It’s a 1944 Model A that has an electric hydraulic pump attached, to operate a plow. I’ve noticed that the pumps’ ground is hooked up to the positive side of the battery. Should this be, or is this thing hooked up wrong? The other large terminal has an arrow stamped under it.
I should also say that it works – perhaps the old saying; “If it ain’t broke, don’t fix it” comes into play here. Thanks, Jim.
Janicholson
04-17-2006 13:13:27
 Re: Farmall Model A hydraulic pump in reply to Jim DeChambeau, 04-17-2006 13:06:35
The tractor (if stock) is positive ground. Go with the flow.
JimN
