Dumping Syndrome
John in WI
04-27-2006 19:52:04
I"ve got a Schwartz loader that won"t hold it"s tilt position. The bucket will even fall when empty. The cylinder is not leaking. Could it still be faulty or do I need to look into my internal hydraulics?
Thanks
John
old
04-27-2006 20:41:34
 Re: Dumping Syndrome in reply to John in WI, 04-27-2006 19:52:04
One of 2 things could be wrong. Cylinder leaking inside or the valve is by passing. Either one will cause that problem.
the tractor vet
04-27-2006 20:04:26
The bucket cylinders could be bypassen inside . I would be doing some checking by loosening the one side of the hose and see if it is pushen oil out when it is not suppose to. Then after that i would be looking at the tractor and BTW just what tractor we worken on here sice it is dark out i can't see it.
Rcubed
04-27-2006 20:07:03
 Re: Dumping Syndrome in reply to the tractor vet, 04-27-2006 20:04:26
You have internal leakage. (piston seals)
