856 IH value??
tim(sd)
04-28-2006 10:20:52
I am going to a auction sale saturday,there is a 856 diesel with cab/rockbox/overhauled two years ago.What do you think will it go for.I havn't seen the tractor but heard it's fair shape.Another question are these a good tractor??Thanks,
Tim(sd)
sammy the RED
04-28-2006 19:29:02
 Re: 856 IH value?? in reply to tim(sd), 04-28-2006 10:20:52
I sold one for $7,300.00
Robhkent
04-28-2006 16:42:07
Tim:
I run an 856D down here in SW IA. Great horse! Starts well in the winter if it is plugged in. A 1500 watt heater for 2 hrs in a building at 0 and it will start before you get your thumb off the starter. If they have the ih front end they do not turn very short. Allan in NE I think has this frint end on his Hydro 70 and he has complained about it also.
Paid $4k for the tractor in 85 with 4000 hours on it. I wouldn't take $7k for it now and it klooks the same as then...working clothes and 7000 hours.
Rob
Nebraska Cowman
04-28-2006 10:55:29
Oh yeah, somewhere in that $5000 range. They are getting too old and with the glowblug start they don't bring the real high bucks. But that is a good tractor and with just a little care will run forever. I was talking to a neighbor the other day and he was wondering howcome that IH has trouble with electolisis sleeve pitting in their engines and JD dosn't as much. My answer was that lots of IH motors will well over 10,000 hrs have never been opened up and most of the JDs have been overhauled long before that.
third party image
Even bad boys are just as good as they can be
RustyFarmall
04-28-2006 11:15:57
 Re: 856 IH value?? in reply to Nebraska Cowman, 04-28-2006 10:55:29
856 diesels do not have glow plugs. They were a bit hard to start when the temperature dropped to about 35 or so, but I believe IH came up with a cure for that by building higher compression pistons which were then included in the overhaul kit. I used to own an 856 and wish I still had it, although I have absolutely no need for such an animal.
Nebraska Cowman
04-28-2006 17:17:13
 Re: 856 IH value?? in reply to RustyFarmall, 04-28-2006 11:15:57
OOps sorry guys, I was on the wrong page that time ;(
third party image
Nat 2
04-28-2006 11:15:22
Senior moment, Cowman?
The 856 has a direct start D407 diesel. No glow plugs.
superih
04-28-2006 14:47:35
 Re: 856 IH value?? in reply to Nat 2, 04-28-2006 11:15:22
I believe that the 407 had dry sleeves so no need to worry about pin holing sleeves. A good 856 with a properly working pump and injectors will start fine when the temps are below freezing.
Nat 2
04-28-2006 10:25:42
Anywhere from $1500 to $8500, depending on many many factors, none of which you addressed in your post. "Fair shape" doesn't mean much, especially if the words are coming out of the auctioneer's mouth...
Figure if:
Engine needs overhaul: $5000+
TA needs to be replaced: $1500+
Needs tires: $2400+
A well maintained 856 is one of the best IH ever made. If it's tired, it's your worst nightmare.
