oil level in the engine keeps increasing. 444 Dies
Rongaudier
04-30-2006 14:37:25
My oil level in my 444 diesel keeps increasing. I"m thinking there is two possible sources:
1: The front seal of the hyrdraulic pump 2: The front seal of the diesel pump
I"m kind of inclined to think its the hydraulic pump.
Anyone else had this problem?
Thanks
old
04-30-2006 17:04:00
 Re: oil level in the engine keeps increasing. 444 in reply to Rongaudier, 04-30-2006 14:37:25
Best way to tell which one it is, is to smell the oil. If it smells real strong of diesel then most likely the injector pump/fuel pump. If it doesn't smell all that much of diesel then probably hyds
FromJB2
04-30-2006 16:44:14
Hi Rongaudier, Is it Diesel fuel or Hytran hydraulic oil that is getting in the crankcase oil?
Possible sources for Diesel fuel:
1)Fuel lift pump on the right side of motor. The diaphram gets a pin hole in and lets Diesel fuel leak into crankcase.
2)Least likely is front seal on injection pump.
Hytran hydraulic oil is probably front seal on hydraulic pump.
Good luck
JB2
