15 or 18 steering wheel
cory scharf
05-17-2006 19:45:16
which steering wheel is the right one for my 1950 C farmall?
Paul Shuler
05-17-2006 20:06:08
 Re: 15 or 18 steering wheel in reply to cory scharf, 05-17-2006 19:45:16
the small one on the C.
CNKS
05-17-2006 20:02:43
The small one, I think the Super C used the large one. I have a C I'm going to do if I ever finish my 460, but I will probably use the larger one this time, used the small one when I did my other C. This one has a WFE, and should be somewhat easier to steer with the larger wheel, but I don't know how much easier.
Mark Peters
05-18-2006 14:17:42
 Re: 15 or 18 steering wheel in reply to CNKS, 05-17-2006 20:02:43
CNKS, One thing I`ll warn you about with going to a larger steering wheel on the C is leg clearance- the distance between the bottom of the steering wheel and the seat is less.I bought a straight C that had the "18 wheel on and it was tight. I think IH must have changed the steering column support when they went to the Super C, to raise it up slightly to accomodate the larger diameter wheel. Or at least this was a problem for me and my chubby legs! Mark
CNKS
05-18-2006 17:24:47
 Re: 15 or 18 steering wheel in reply to Mark Peters , 05-18-2006 14:17:42
I've thought about that, I'll probably try an old 18 inch that I have first and see.
