300U clutch adjustment
300Randy
05-24-2006 05:37:46
My 300U runs for more than 10-15 minutes now, must have been the points and condenser. Anyway I went to adjust the clutch and TA following the directions in a copy of the orginal manual. As I got into it I realized that all the adjustments have been maxed out. The one adjustment for the TA had me move the bracket that comes out of the side of tractor case counterclockwise and then adjust the linkage for 3/16 inch play. The linkage is as far as it will go ane I have about 1.0 inch of play. What do I have to replace to get back into spec? Is my clutch wore out? I know some of the linkage looks a little worn. How big of a job is it to rebuild the TA? Thanks
Levi K
05-24-2006 19:28:35
 Re: 300U clutch adjustment in reply to 300Randy, 05-24-2006 05:37:46
third party image
Rebuild the T/A? get out yer checkbook if you want ot have pro do it, but you can do it yourself, it's not that hard, I rebuilt the T/A on my 300 rowcrop. Here's some pics. of my expirence. you can buy a video of how to do it on theis website.
