Broken inner rim on my H
RMO/MN
06-09-2006 20:10:03
The inner rim on the front of my H is broken out at one of the mounting bolts. can these be repaired or do I need to start looking for a new rim. If I have to locate a new rim any ideas I'm in southern MN
Bob
Randy as in Randy-IA
06-11-2006 13:10:48
 Re: Broken inner rim on my H in reply to RMO/MN, 06-09-2006 20:10:03
Hi Where in Mn are you ? I know a salvage yard about 40 miles from me that has those hubs just scattered all over the ground . Price would be reasonable and they ship too . Otherwise , maybe try ebay because some of those tractor jockey's part out perfectly running tractors just so they can make a couple dollars more off them . But that's a different whine with my beef ! Good luck ! ...Randy
RMO/MN
06-12-2006 05:39:40
 Re: Broken inner rim on my H in reply to Randy as in Randy-IA, 06-11-2006 13:10:48
Randy,
I'm in Prior Lake so northern Iowa isn't to far. Could you send me the phone number to your salvage yard.
Bob
Janicholson
06-10-2006 06:28:02
If the rim is not too rusted out, prepping and welding the break is certainly possible. There is probably a welding school close to you that would assist in putting it in operation. Make sure there is enough material to get good penetration, and then it can be smoothed off to be less recognizable as a weld, Leave no snags on the inside to pierce the tube.
JimN
RMO/MN
06-10-2006 07:19:03
 Re: Broken inner rim on my H in reply to Janicholson, 06-10-2006 06:28:02
Hello Jim,
The part of the wheel I'm talking about is the inner wheel which is cast maybe the proper name would be the hub.
Bob
Janicholson
06-10-2006 16:50:55
 Re: Broken inner rim on my H in reply to RMO/MN, 06-10-2006 07:19:03
A broken Cast hub (term is correct) is more difficult to weld, but very possible. The best solution is a different one, they are pretty common in bone yards. The effort it would take would not be worth the difference in price. Plus it would be difficult to finish the weld to appearance satisfaction. Sorry JimN
River Bottom Farmer
06-09-2006 20:24:30
I wish you lived a little closer,I have a parts tractor that I would sell you parts off of cheap.I live in central Ohio so I dont think I will be any help to you,but I do have the parts you need and they are in good shape too.RBF
