3 PT on S/M
Lerm
06-10-2006 08:40:31
I've got a S/M with a homemade 3 pth on it with one hyd cylinder, was wondering if the hyd system would be able to lift a 7' bushog aprx wt of 925lbs. appricate any help
River Bottom Farmer
06-10-2006 08:58:19
 Re: 3 PT on S/M in reply to Lerm, 06-10-2006 08:40:31
Lerm, I built my own three point hitch on my 39 H and I used two 2 1/2 inch cylinders on it and it will lift the front tires off the ground if I hook to something too heavy.I use a seven foot draw bar type mower that weighs in at around 1400 pounds and it lifts it easily, and it lifts everything else real easily too.I figuire you have around a 750 psi hydraulic system on the M so if your cylinder is big enough it will most likely lift it unless your hydraulics are weak.Do you use the hydraulics for anything else?Just wondering if you had a way to tell how your pump was putting out as far as pressure goes....RBF
