problem sttarting my farmall c
george2125
06-25-2006 10:50:45
I just rebuilt my farmall c , put everyting back together,and it wont start.I have good spark,it turns over good, and i think i timed it right. Need some help to start it up. Thanks George
gene bender
06-25-2006 13:11:57
 Re: problem sttarting my farmall c in reply to george2125, 06-25-2006 10:50:45
Get #1 on compression T.D.C. Then make sure the rotor is lined up with the terminal going to #1. Facing the dist cap #1 is about 2 oclock.
old
06-25-2006 12:36:04
You might have it timed 180 out and if so it will not run. They way I check that is pull 2 plug wires and switch them from one side of the cap to the other side of the cap. If it starts on 2 cylinders then you know you are 180 out and you just need to switch the other 2 then
george 2125
06-25-2006 13:15:07
 Re: problem sttarting my farmall c in reply to old, 06-25-2006 12:36:04
old i did it the way you said and it worked.now i have another question.run the tractor like this or re time it?
old
06-25-2006 14:33:06
 Re: problem sttarting my farmall c in reply to george 2125, 06-25-2006 13:15:07
If it where me I would just leave it that way. But you could pull the distubutor off and turn it 180 and then put the wires back on but as I said I would leave it, but I'm lazy so. It will not hurt anything if thats what your worryed about. One of my tractors is 180 out as far as how the book says it should be and has been ever since I put the new mag on it and that was 4 years ago
Don L C
06-25-2006 14:30:19
I would turn the dist. 180, put the plug wires back where they are suposed to be and time it acording to the manual.....
